Discussion topic: Internet not working
Message posted on 25 Jul 2025 11:37 PM
Internet is not working Internet light flashing orange ?
Message posted on 26 Jul 2025 04:16 AM
Re: Internet not working
@K_young01
If your broadband still isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
