Discussion topic: Internet not working
This message was authored by: Davy_tillman
Hi my Internet is not working. Everything us contect but shows not internet
Re: Internet not working
@Davy_tillman
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
