Discussion topic: Internet not working
Message posted on 10 Jul 2025 08:51 PM
My internet is not working and the voice light is red on my box. The app says there's an issue, when I click fix the issue it runs the scan and says everything is fine.
Message posted on 10 Jul 2025 09:30 PM
Re: Internet not working
- Hi Gina Ours is not working either where in uk are you
Message posted on 11 Jul 2025 04:45 AM
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 12 Jul 2025 05:51 AM
We are in Bristol, it came on eventually been running really slow since
