Discussion topic: Internet not working
This message was authored by: AnaisG
Internet not working. Turned box off and back on again. A few of the lights have come back on but not all of them.
Re: Internet not working
@AnaisG What lights are on/off, below link about hubs and lights.
@AnaisG
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
