Discussion topic: Internet not working
This message was authored by: Charlotte161
Watching the tv when the internet has dropped. I have tried restarting the router. I have also turned it off at the wall. I have checked the status and it says there's a problem let's fix it. It doesn't fix it!
Re: Internet not working
@Charlotte161  Are you in the IP1 or IP4 postcode areas?
Avatar for Charlotte161
Level 0 icon
Hi there.
No im in DA3
@Charlotte161 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
