Discussion topic: Internet not working
This message was authored by: christina36
For the last 2 days our WiFi has intermittently not been working. It will not work for a couple of hours and then will work for a hour. It's not good enough as I work from home so I'm anxious about how it will be tomorrow when I'm working from home.
Re: Internet not working
@christina36
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
This message was authored by: EvelJim
Service checker just says "not available right now"
