Discussion topic: need to find where to order a new replacement router
Message posted on 17 Apr 2025 02:20 PM
hey there, can anyone point me in the direction of where i can order a new replacement router ?
as the one i have seems to have an issue with it, when setup correctly
i've tried the service checker with no luck it says everything is fine despite the internet light being stuck on amber, have done tests with another router and that works correctly in less than a minute when it gets plugged in, have also tried the general sky 03337 number to no avail either
literally, just need a new replacement router so any options ?
thanks in advance
Message posted on 17 Apr 2025 02:48 PM
Re: need to find where to order a new replacement router
@TobyG Unless you call sky, it's the only way to get what you request.
Message posted on 21 Apr 2025 10:31 AM
cool, thank you !
appreciate the reply & help; should be resolved now anyways
