Discussion topic: Internet not working
This message was authored by: Mattandkathy
Internet not working. 3 out of 4 lights on modem and same on router. Tried resetting multiple times.
Avatar for Mattandkathy
Level 0 icon
Re: Internet not working
Also tried the online test but it states everything OK
@Mattandkathy
There's a current outage in south Cornwall but otherwise use the below link to check to see if there are any problems or outages nearby
HAPPY NEW YEAR
Level 0 icon
Run tests, says everything ok, nothing working. Phone line not working so can't call the number provided. Internet has been dropping circa 3 times a day and requiring reset up to this point. I really need more support than this
@Mattandkathy
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
To call Sky dial 150 (free) from a Sky Talk landline or a Sky mobile or alternatively use the following link
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
HAPPY NEW YEAR
