Discussion topic: Internet not working..
Message posted on 08 Feb 2025 08:30 PM
Internet isn't working nothing will load up on tv/phones ect.. Nottingham area
Message posted on 08 Feb 2025 08:52 PM
Re: Internet not working..
@Marthamae
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
Message posted on 08 Feb 2025 08:53 PM
@Marthamae First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 09 Feb 2025 12:55 PM
Hi mt broadband isn't working it is showing a red light
Message posted on 09 Feb 2025 01:05 PM
Message posted on 09 Feb 2025 01:19 PM
Have you run the line test as per the post above yours ?
