Discussion topic: Internet not working
This message was authored by: Georgia55
Message posted on 26 Dec 2024 05:52 PM
Not working
Find out more
Message posted on 26 Dec 2024 06:01 PM
Re: Internet not working
The first thing to do is check to see if there are any outages in your local area via this link https://www.sky.com/servicechecker
If there isn't try running the line test here
You can also run the test via the MySky app on a mobile data connection. Once completed, if it reports back that all is good click on 'broadband' to run an updated test.
If you get amber or red you need to follow the on screen instructions.
Feedback
