Discussion topic: Internet not working
This message was authored by: Toni_
When testing broadband issue it shows there isn't any. But my middle light on the sky box isn't on and I can't access the internet
Re: Internet not working
@Toni_ the service check shows the position when the check was run which can be some hours before. The lack of an internet light inducates the hub has lost connection. You can click through on thecservice checker to test the Broadband which will tell you if Sky are aware of an issue on your line. If they aren't call them to report it so they can get it checked out.
