5
This discussion topic has been answered Discussion topic: Internet not working
This message was authored by: John249
My internet connection is down and has been for the past hour. I have checked all the connections and there is nothing obstructing the router. I need help
This message was authored by: jamesn123 Answer
Re: Internet not working
Hi @John249
Have you run the line test in the My Sky app?
I am NOT a Sky Employee
Hi @John249
Avatar for John249
Yes I did it's ok sky are sending out an engineer as the fault is in the master socket. Thank you anyway.
This message was authored by: Mari5
My internet isn't working. App suggests there are no issues in the area and my broadband should be working
Avatar for John249
I had this yesterday switched everything off for 30 seconds seems to be ok now.
This message was authored by: Elaine5337
My broadband keeps crashing, so fed up of this crap now!!
