Discussion topic: Internet not working blackpool
Message posted on 27 May 2025 02:11 PM
Internet not working, hub ok no Internet message. Tried all the suggestions and still not working since midnight last night
Message posted on 27 May 2025 02:12 PM
Re: Internet not working blackpool
@urban+warrior
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
