Discussion topic: Internet not working berkshie
Message posted on 08 Jul 2025 04:38 PM
I have turned the internet on and off multiple times and checked the service on the website, which says it's fine, but it is not working on phones or tv
Message posted on 08 Jul 2025 04:41 PM
Re: Internet not working berkshie
@Lydiaq
If your broadband isn’t working use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
