4
This discussion topic has been answered Discussion topic: How to find update on Sky broadband installation on hold
This message was authored by: AyuBaker
Hi, I had two engineers came on Friday 4th July tried to install broadband, however they've found that they need to create new cable short cut to create a broadband connection to my property. To do this they'd need digger to come and pull the cable out. I have not heard anything else from Sky or engineer about the current status of the dig and installation since. How do i contact Sky please to find out the sttaus?
I've no WIFI connection for more that a month now as I just moved to this property.
This message was authored by: JimM1 Answer
Re: How to find update on Sky broadband installation on hold
@AyuBaker Call them, the number is in the link below, just do the need more help to see it!
https://www.sky.com/help/home
Likely to be a considerable wait, unfortunately.
Avatar for AyuBaker
thank you! phoned and advised that I need to wait for digger to come and do it.
Avatar for AyuBaker
Thanks and you're correct. I'd have to wait as it's a third party digger they appointed. so must wait.
