Discussion topic: Internet not working again
This message was authored by: Ted76
Outage in local area for 2 days Internet back on and after 2 hours Internet light on hub has gone off again. Getting really cheesed off with this think I'll change broadband provider as sky no help
Re: Internet not working again
@Ted76
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
