Discussion topic: Internet not reaching bedroom
Message posted on 07 Dec 2025 10:47 PM
Never had a problem with connection to all devices but my bedroom smart tv stick now keeps struggling with the internet saying it to low in signal
Message posted on 08 Dec 2025 05:41 AM
Re: Internet not reaching bedroom
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 08 Dec 2025 08:39 AM
@Madison15 If everything else is fine then the issue will be your Firestick!
