Discussion topic: Internet not happening
This message was authored by: Leah8989
No internet connection in the home
Started the router again
Re: Internet not happening
@Leah8989
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
