Discussion topic: Internet not connecting middle light keep flashing red
This message was authored by: Bjorn1
This message was authored by: Kd2198
tRe: Internet not connecting middle light keep flashing red
Same here, middle light on my Huawei router keeps flashing red and there's a fixed amber light on the actual sky router.
Been fine all the time but as of right now there's a total blackout. I can't even watch anything on my sky glass TV?!?!!!?!
@Bjorn1  & @Kd2198 if you lines are still down and the My Sky connection check is not showing Sky are aware of a fault on your line give them a call so they can get it fixed. If you are using a third party router swap in your Sky hub before calling as any disgnostic tests will require that.
