Discussion topic: Internet losing connection
This message was authored by: RSmith2
We've had sky internet since January, initially we had an issue and ending up having to wait for an engineer to install something, since then we constantly have issues with the internet losing connection. I'm not sure whether everything was installed correctly in the first instance, but as you can imagine this is causing us no end of problems as I work from home, and rely heavily on having an internet connection to carry out my work
Re: Internet losing connection
@RSmith2
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
