Discussion topic: Internet light on hub not on
Message posted on 18 Sep 2025 10:27 AM
Everything is working fine, I've done all the troubleshooting and tested my broadband everything is saying fine yet the hub light is not on
Message posted on 18 Sep 2025 10:38 AM
Re: Internet light on hub not on
@PaulSFC Not sure of which hub you have as you do not say, but if you care to reboot the hub you may see light change and it may just be that the light for particular is now failed!
Message posted on 18 Sep 2025 10:40 AM
All that has been down, rebooting the system etc. Turns out sky was down in my area yet when I was doing the health check it was saying all good. Oh well it's working now thanks
Message posted on 18 Sep 2025 10:43 AM - last edited: 18 Sep 2025 10:44 AM
@PaulSFC Glad and take it your light is on now, they are the ones to trust and not what you get reported back on the app for connection, you also started off with "Everything is working fine," so little bit misleading with your post!
