Discussion topic: Internet light amber
Message posted on 15 Jun 2026 08:18 PM
The internet light on my sky hub flashes amber and then goes to full amber. I have tried resetting everything and going through all instructions however this issue keeps happening.
It says my WiFi is all good and up to speed but I have not internet!
Message posted on 15 Jun 2026 08:21 PM
Re: Internet light amber
@Afowler
Even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
