Discussion topic: Internet keeps not working !!!!
This message was authored by: lucyjane123
Please can someone sort out internet out it keeps coming on and off
This message was authored by: MattyHol
Re: Internet keeps not working !!!!
Mines the same and it's driving me crazy
I keep ringing and they are saying things are fine their end
@lucyjane123 What are you seeing when this all happens, see the link below!
@MattyHol Link is the same for you as above!
Avatar for lucyjane123
It's saying  there has been a problem finding your sky q box and all our internet doesn't work
@lucyjane123 Do you have one or two problems, nothing working will be the hub, the link shows you what and if you do not say then the Forum as customers like you cannot respond, if it is a Sky Q box not connecting to the hub then that is a different issue.
Posting on the Forum you are not talking to sky direct! If you need to do that then give them a call!
