Discussion topic: Internet keeps going off
This message was authored by: Robert886
My internet keeps going off we have reset it numerous times but its not working but on the app it says its all good but the box is unplugged at thw moment so how is this true ?
Re: Internet keeps going off
@Robert886
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Avatar for Robert886
We have used this but the Internet box was off at the time we checked but it still said there was a great connection . The was obviously no connection as it was turned off 🙄
@Robert886
@Daniel0210 wrote:
@Robert886
