Discussion topic: Internet keeps going off
This message was authored by: Andrea1171
It goes of at least twice a day,been doing it a couple of weeks,service is rubbish
Re: Internet keeps going off
@Andrea1171
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
