Discussion topic: Internet keeps going off
This message was authored by: Louise245
Hello.
twice today my internet has went off. I have checked on the app and it's showing everything is ok but on my router there's a red light.
twice today this has happened to me I've never had any issues before
Re: Internet keeps going off
@Louise245
