1
This discussion topic has been answered Discussion topic: Internet keeps going off, even with Wifi
This message was authored by: Dottie15
Internet has been going off and on all week, even though WiFi is on
Re: Internet keeps going off, even with Wifi
@Dottie15
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Dottie15
