Discussion topic: Internet keeps going down
This message was authored by: Louise+naomi
So it's saying all is fine with the set up but tvs and phones are not working as saying no internet connection on everything
Re: Internet keeps going down
@Louise+naomi
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
