Discussion topic: Internet keeps going down
This message was authored by: Kat551
my WiFi has been on and off all morning. I'm trying to get some important work completed but this is just painful- Sky broadband is terrible- this happens a lot. Not a v happy customer- help?!
Re: Internet keeps going down
@Kat551 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
