3
This discussion topic has been answered Discussion topic: Internet keeps cutting out
This message was authored by: Saracutting
My Internet has cutting out 3 times this evening lasting from 5 to 15 minutes a time. When I do the check it says no issues detected. Two lights keep going orange on my router.
Re: Internet keeps cutting out
@Saracutting
@Saracutting
This message was authored by: Stephh_
I'm having the same issues 😞
@Stephh_
The same advice applies.
