Discussion topic: Internet keep dropping out
Message posted on 26 Nov 2025 10:56 PM
Message posted on 27 Nov 2025 04:58 AM
Re: Internet keep dropping out
@Julie+pa
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
