Discussion topic: Internet drops out
Message posted on 26 Nov 2025 11:50 PM
Internet drops out
For a few days this week the router stops working. We get 3 green lights and one orange. Re booted doesn't have an effect. Can someone help
Message posted on 27 Nov 2025 04:59 AM
Re: Internet drops out
@Angela176
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
