Discussion topic: Internet issues
This message was authored by: jenson20
Internet issues
Hi my internet keeps going off can you help please
Re: Internet issues
@jenson20
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
