Discussion topic: Internet issues
This message was authored by: Raddy1
Internet issues
My internet is not working, on the router the internet is not turning green and the voice is orange
Re: Internet issues
https://helpforum.sky.com/t5/Broadband/bd-p/sky_broadband
Avatar for Raddy1
Re: Internet issues
What does that mean @Anonymous
Re: Internet issues
It meant you were in the wrong forum but someone has moved your post for you since I posted.
Avatar for Raddy1
Re: Internet issues
How do I fix my internet @Anonymous
This message was authored by: dueyfinster
Re: Internet issues
@Raddy1  where are you based? I think the service is down - I seem to be affected also.
Avatar for Raddy1
Re: Internet issues
I'm from burnley which is near blackburn.
Re: Internet issues
1st step would be to power off the router for at least a minute, and see if fault clears once it reboots.
Takes about 5 mins to reboot.
If not working, use a mobile on mobile data, log into your sky account and fined option to test your broadband connection.
Re: Internet issues
Ah okay I'm based in Ireland so different issue.
