Discussion topic: Internet issue
This message was authored by: Umurova
Internet issue
Hello, My wifi signal disappeared. Please advise what happened? I see yellow signal on my wifi router, instead of green.
Re: Internet issue
@Umurova
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Avatar for Umurova
Re: Internet issue
Thanks a lot for your reply))
Noted. It was too easy to be the truth that I managed to contact Sky Customer Service at night!:-)
Re: Internet issue
@Umurova
If it's still down, and you haven’t done it already, use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
