Discussion topic: Internet is not working
Message posted on 15 May 2025 07:51 PM
I have set up the cables as per in guide but still internet button on the hub is not green. I have connected ethernet cable to open reach modem and port 4 in WAN in the hub and powered on in the both open reach modem and hub. I have fiber connection. Can anyone help me with this?
Message posted on 15 May 2025 08:15 PM
Re: Internet is not working
When was your activation date ?
Message posted on 15 May 2025 09:13 PM
It’s on 13 th of May. I have a doubt with the ports which I connected. There's no phone cable? I just only connected ethernet cable.
Message posted on 15 May 2025 09:23 PM
@Nala241 Black or white hub. If black what are the first digits of the serial number D2 for the UK and DE for ROI, been a few mixups with wrong hubs to wrong locations.
Message posted on 15 May 2025 09:32 PM
Black hub and D210
Message posted on 15 May 2025 11:19 PM
@Nala241 SR203 sky hub, and with the D2 then good for connecting to the UK. On the OR ONT do you have 3 green lights, Power, Pon and the Lan flickers as the hub sends data to it?
Message posted on 15 May 2025 11:45 PM
I have the exact same problem and have the 3 lights on
Message posted on 15 May 2025 11:53 PM
@JimM1 Yes all of them are green
Message posted on 16 May 2025 07:20 AM
@Nala241 It does sound like there is either a problem with your hub, or that openreach/sky have not activated your connection correctly. If you look on your sky My Messages you should see the state, you should also have received a text from sky around you 13th saying that you are now activated and to connect your router. As you are no internet light or an orange light then you have to call sky and get them to take a look, you could try to power off the ONT and wait for it to boot up again to the 3 green lights but do not think it will clear up the connection issue for you.
Message posted on 17 May 2025 11:32 AM
Okay How can I contact sky team I couldn't find any contact number. It seems like there's a problem in the connection.
Message posted on 17 May 2025 12:37 PM
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
