Discussion topic: Internet is not working
Message posted on 25 Jan 2025 03:13 PM
Unable to connect to the Internet, all devices are unable to connect but when we check online it's reporting no issues.
We are also unable to connect to online series such as Disney, Netflix and Google home is unavailable.
This has been happening since yesterday afternoon, we have rebooted the modem several times with no success in resolving the issue.
Message posted on 25 Jan 2025 03:21 PM
Re: Internet is not working
@JLJR
The lines will be particularly busy at present due to the damage and disruption caused by Storm Éowyn.
