Discussion topic: Internet hub keeps going offline
This message was authored by: wilkco701
Every few hours hub goes down. Reset it and it came back. This time it's not hasn't
This message was authored by: mae-3
Re: Internet hub keeps going offline
@wilkco701
The power supply with or in the router depending on which router you have has failed. You will need a new router and power supply and this you'll need to contact Sky about to source, or hopefully a superuser will esculate the post to Sky so they can arrange a new wireless router.
