Discussion topic: Internet going down
This message was authored by: Elouize
Internet going down
Our internet keeps going off randomly for no reason, all checks say that its fine, are has no outages but it keeps disconnecting and turning off and then coming back on 2 minutes later.
Re: Internet going down
@Elouize
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Avatar for Elouize
None of this has helped unfortunatley, internet keeps going off, have tried everything.
@Elouize then call Sky in the morning so they can get the issue checked out but note if you have a partial fibre connection in an area hit by last night's storm there will be a delay in getting any action as loads of lines will have faults.
