Discussion topic: Internet drops out every hour
Message posted on 04 Sep 2025 08:51 PM
Internet connection keeps dropping out. Happens every hour or so. Sky checker says everything is fine but it isn't. Looking at swapping services as cannot keep going on like this.
Message posted on 05 Sep 2025 07:54 AM
Re: Internet drops out every hour
@Mike_01 if you sre out of contract swapping is an idea but beforecdoing so consider if the problem is a line issue moving to another ISP who uses the same line almost certainly means the problem moves with you.
Instead report the issue to Sky depending on the number and frequency of the line drops (lights on the Skyhub change) they should be ablecto get Openreach to check your line.
