Discussion topic: Internet dropping out on regular basis
Message posted on 03 Mar 2024 09:29 PM
Message posted on 03 Mar 2024 09:48 PM
Re: Internet dropping out on regular basis
Yes did sky resolve this for you?
This is seriously impacting remote working.
It's dropping out throughout the day
Message posted on 03 Mar 2024 10:19 PM
@Wendy566& @colclark79 when the internet drops again or you can check just now to see if an external fault is found using the information below.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 04 Mar 2024 07:35 AM
Cheers pal, run all the tests and it is not picking up a fault but identifying that there is an issue. Going to give sky a call today wish me luck 🤞🏽
Message posted on 04 Mar 2024 11:24 AM
@colclark79You are saying it did not pick up any faults, but picked up an issue? What was the issue?
