Discussion topic: Internet dropping out and cutting off repeatedly
Message posted on 17 Jul 2026 07:35 PM
I switched to sky recently for better internet connection and it seems to be worse please help the internet keeps crashing and cutting out
Message posted on 17 Jul 2026 07:38 PM
Re: Internet dropping out and cutting off repeatedly
On your devices what is the wifi signal like ?
Is your broadband hub out in the open and not near any electrical devices ?
Message posted on 17 Jul 2026 07:40 PM
The lights are all green the white box has a light light on the box is in a empty space
Message posted on 17 Jul 2026 07:42 PM
Message posted on 17 Jul 2026 07:43 PM
The lights are green and the white light is lit on the box everyday the internet drops out I check the speed with the speed test and it goes to 3/4 it should read 300, the other side goes to 16 it should be closer to 30
Message posted on 17 Jul 2026 07:45 PM
I just ran a speed test and the first speed went to 200 and the other speed 42. I thought I would check it but it will go down again it is doing it every day now
Message posted on 17 Jul 2026 07:53 PM
Again I will ask, what is the wifi signal showing on your devices, is it on the weak side ?
Message posted on 17 Jul 2026 08:05 PM
At the moment it is ok but it will drop as it has been
Message posted on 17 Jul 2026 08:16 PM
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
