Discussion topic: Internet dropped lan flashing
Message posted on 23 Dec 2025 10:54 PM
Internet dropped and now can't get back in. On huwaei pon flashing light lan flashing light and los off.
Santa bringing a PlayStation here and no internet access all of a sudden is killing me
any suggestions would be greatly appreciated
Message posted on 23 Dec 2025 11:06 PM
Re: Internet dropped lan flashing
@DouglasGunner From the sky help!
Optical Network Terminal | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 23 Dec 2025 11:33 PM
I've gone through all the suggestions.
the pon and lan lights are flashing green but still no internet.
is there anything that can be done
Message posted on 23 Dec 2025 11:35 PM
I had a similar problem about 6 weeks ago and I got onto the helpdesk. They said the connection was good to the house but internally there was an issue.
I got no engineer visit but it came back on again
here I am again at the worst possible time
Message posted on 23 Dec 2025 11:40 PM - last edited: 23 Dec 2025 11:44 PM
@DouglasGunner To start with are you saying that the PON is flashing Green because THAT is a NO NO!
You can try the ONT off for 5 minutes, then power it back on, if the PON flashes it's a call to sky!
Message posted on 24 Dec 2025 12:12 AM
I've done this a few times and the pon flashes
Do you mean I will need an engineer visit
Message posted on 24 Dec 2025 08:18 AM
@DouglasGunner you need support from Openreach but not necessarily an engineers visit so call Sky if tgevoonline servicecchecker is not offering to book an engineer..
My own line has had several similar issues in recent weeks where the PON light pulsed green, the LOS light remained unlit and my Sky hub indicated it was trying to connect but could not. The issue was with the equipment generating the opticsl signal at the exchange where it was not sending the correct id for my ONT to lock onto. According to the engineer who came out they had reports from at least one of my neighbours who had an identical issue.
The fibre network is passive (the P in PON!) so the issue was either with my ONT or the OLT at the exchange they could rule out the ONT as multiplecreports on the same distribution point. This went on for a couple of weeks with the connection coming back on its own and dropping again a few hours later. Openreach have told Sky they have resolved the fault a week ago. So far 🤞it has stayed up. Sky customer servicescare around over the holiday but Openreach wont attend until after the holiday unfortunately.
