Discussion topic: Internet drop out
This message was authored by: Kkirk
Internet drop out
My WiFi is connected but apparently I have no Internet, I have ran the checks on the app and all apparently is ok!.. this keeps happening and thinking of changing provider.
Re: Internet drop out
@Kkirk  Can you follow the latter part of the directions below. Tha is if the service checker shows everything is okay.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
