Discussion topic: Internet dripping in and out
This message was authored by: Chelski
Since I have switched product with sky my internet is dropping out while I am on work calls in meetings which is not great! I will have to look at a different provider as it was fine before and now it is even worst and I need internet for work. Very important for my work. Thanks
Re: Internet dripping in and out
@Chelski
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
