Discussion topic: Internet disconnecting repeatedly
This message was authored by: KW993
Three times yesterday evening, Internet connection was lost and again today. Rely heavily on this due to remote area and poor mobile reception
Re: Internet disconnecting repeatedly
@KW993
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
