Discussion topic: Internet cutting out
This message was authored by: Will2468
Hi our internet keeps cutting out.  This has been happening for 48 hours.
Re: Internet cutting out
@Will2468
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
Avatar for Will2468
Thanks for the advice.
