Discussion topic: Internet cutting out
This message was authored by: baldie07
My Internet keeps cutting out but the checks say its ok.
Re: Internet cutting out
@baldie07
If you haven’t done it yet use this link to check to see if there are any issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
