Discussion topic: Broadband off
Message posted on 04 Nov 2025 10:07 AM
Broadband off
Message posted on 04 Nov 2025 10:10 AM
Re: Broadband off
Hi @DanHardingham have you tried rebooting your router ? Worked for me.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 04 Nov 2025 10:29 AM
Re: Broadband off
If that doesn't work try this link to check to see if there are any issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Message posted on 04 Nov 2025 10:33 AM
Re: Broadband off
Me too unfortunately. So annoying
Message posted on 04 Nov 2025 10:35 AM
Re: Broadband off
Try the advice already provided.
Message posted on 04 Nov 2025 11:26 AM
Re: Broadband off
Tried all fixes, and not working.
Message posted on 04 Nov 2025 11:28 AM
Re: Broadband off
Yes, no good. But thank you.
Message posted on 04 Nov 2025 11:30 AM
Re: Broadband off
In that case @Cavernwight
@Daniel0210If you’re still having problems you may need to contact Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Re: Broadband off
Me neither.
Message posted on 04 Nov 2025 12:26 PM
Re: Broadband off
@DanHardingham wrote:
Me neither.
No idea who you're replying to there as you haven't tagged the user name.
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟦 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟦 online help via this link
https://www.sky.com/help
🟦 Sky Assistant 💬 should also be available via
🟦 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
