Discussion topic: Internet connection
This message was authored by: Dan10859
Internet connection
My internet connection keeps disconnecting, sometimes for days, I have
sky sports and movies but no apps,
Re: Internet connection
@Dan10859
You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is made up predominantly of Sky customers helping other Sky customers which includes additional help from customers who are Superusers like myself.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
